Fibaro FDG211 & S2
I have a dimmer Fibaro FDG211 with two switches.
The first is a mono stable switch. It's connected to S1.
The second is a bi stable switch. It's connected to S2.
So, if I choose in module Fibaro as bi-stable (parameter "Swithc type") and if I create a link with another dimmer, it's work. Obviously I need to create a rule so that my mono stable swith works like a mono stable swith.
But if I choose in module Fibaro as mono-stable (parameter "Swithc type"), my s2 switch never works.
So my question is : It's normal ?
And if it's not normal, what am I doing wrong ?
Thx
I also ran into this issue.
According to the manual you can only bind/associate the input 2. But when I bind a devices nothing happens.
But i have to do some more testing on this.
