Fibaro FGDW-002 (Door/Window Sensor) not configurable due to JS Error in Web Frontend
Hey Zipas!
I have just connected my new Fibaro Sensor to the Zipamicro. Most of it works: Sensor Values, Triggers and I can use it in Rules.
But I can not configure the main node! Clicking on "Save" in the Web App just does nothing. It is possible to change the configuration of a (sub) sensor but not of the device itself. So no naming and no configuration of the update interval. That's quite bad for a battery driven device.
Deleting and reconnecting sadly did not help.
The cause for not saving is a JS Error of the web frontend:
app-classes.js?v=1.5.9:1 Uncaught TypeError: Cannot read property 'length' of null
at Object.<anonymous> (app-classes.js?v=1.5.9:1)
at Object.each (ext-all.js:21)
at Object.iterate (ext-all.js:21)
at j.setDeviceConfigData (app-classes.js?v=1.5.9:1)
at j.sendSaveRequest (app-classes.js?v=1.5.9:1)
at j.saveDevice (app-classes.js?v=1.5.9:1)
at A.fire (ext-all.js:21)
at A.dispatch (ext-all.js:21)
at A.a.fireEventArgs (ext-all.js:21)
at A.fireEvent (ext-all.js:21)The Problem occurs in Chrome and Firefox. Any Ideas?
This is a known problem that I've reported. Apparently, a new web front-end is close to launch and it will be fixed there (maybe?!)
