Fibaro FGS221 binding
How I can deactivate "internal" binding drom FGS 221? I have wall switch connected to input S1 and lamp connected to output O1, but I down want to controll O1 with S1 signal. Now every time I turn S1 on, also lamp on O1 will turn on. If I select from Bidings page some else module output, it will control it but also O1 from module where S1 is.
I've the same question: how to deactivate native binding.
I am pretty sure that S1 and O1 are effectively hard wired together (as are S2 and O2) so you can't separate them. What exactly did you want to do with the switch and the light?
/Marcus
/Marcus
