Fibaro Flood Sensor Settings
            What should the wake up interval be in the In configuration menu of the Fibaro Flood Sensor?
the wake up interval for Fibaro FGFS-101 flood sensor is by default set to 7 min. This is done so that the users can configure the sensor more easily.
After you have configured your device you should set the wake up interval to 2-3 hours since you won't be configuring your sensor so often anymore and there is no need for the sensor to connect to Zipabox so often.
Please take note that this will not effect how often the sensor is sending measured values to Zipabox (flood, temperature)
Hrvoje
Hrvoje
Thank you Hrvoje.
On a similar topic, what should the wake up interval be for the Fibaro Door and Window Sensor be as mine aren't set to anything?
Thank you Hrvoje.
For the same reasons as mentioned before, after you configure your device set the wake up time to a few hours to maximize the life expectancy of your batteries.
Kind regards,
Hrvoje
Kind regards,
Hrvoje
