Fibaro Motion Sensor (Temperature) in Climate Widget doesn't work
Anyone tried to use the Fibaro Motion Sensor as temperature input in the climate widget?
Temperature is displayed in the meters section and displayed correctly.
I only get Custom / 0.0 degrees in the climate widget
Slashroot
I check at this moment with a factice climate widget
I have the same probleme.
same error with fibaro fire detection.
Hello, Do you have the issue in the "new GUI" ?
I used a fibaro motion detector (fgms-001) as a temperature input in a climate widget. I had the same issue when I created the thermostat about 2 months ago (ref the post : https://community.zipato.com/responses/can-not-use-fgms-001-temperature-sensor-in-the-climate-module-)
But this issue disappeared by itself after a couple of hours. Than it worked for about 2 months.
Now, with the new GUI, I again have an issue. Current temperature that is displayed is "0".
