Fibaro RGBW controller not showing right status
HeroS - www.domotica-blog.nl shared this problem 13 years ago
When i use a rule to controller the Fibaro RGBW it doesn't show the right status on the dashboard and App. I set it to 50% but is shows 7%.
And when i manual switch off the RGBW it's not showing that its off.
Replies (5)
any update on this?
I have made some adjustments to the descriptor for this device to fix the above problems. Please remove it then add it again.
Hi Marko,
Do i really need to remove it? I have a lot of rules with this devices and removing it i have to remake/update all the rules. Not very funny.
Does the reply descriptors not work?
Hi Milan,
The re-aplly did not work. Today i finally got to remove and add the device again.
But still does not shows realtime updates.
The light changes with the rule but don't see the right level in the dashboard. Also when i put it on 100% trough the dashboard it flips back to 7% (last level). It only updates when the event panel show the right value. The event panel show values about 3 min. to late. Maybe this has something todo with it.
Can u please look at this.
I have send a email to support about this.
