Fibaro smoke sensors battery problem
charriernicolas shared this problem 12 years ago
thinth a few week, my smok sensors FGSS-001 report me battery low. I change the battery, and 2 week after same problem, battery low.
When i check zwave range with this module, no zwave detected. Is there somthing in zipabox that chang on zwave network that do a high power consuption?
I thinks the problem is the same wiith zipato kepab, battery is low very fast.
It was better battery life for device with precedent firmware.
Is there sombody with same problem?
Thank
Nicolas
maybe your Fibaro FGSS-001smoke sensor is communicating with your ZipaBox to often. In Control Center please go to Total devices and click the folder Fibaro FGSS-001. In Configuration menu if the Wake up interval is set to high, you should set it to 120 min.
Hrvoje
Thanks for thaht advise.
as i use also the fibaro smoke sensor for temperature, I configure Wake up intervale to 60min (like temperature report is configured at 720 * 5s )
I will check if it change smothing with 2hours configuration.
