Fibaro Universal Sensor FGBS321 v2.1 - v2.3
DaBoss shared this idea 13 years ago
This module seems to be supported by zipato however in manuel there is more parameter than zipato display in the configuration tab . . .
/Vgi6y8v1gsAAAAABJRU5ErkJggg==
There some parameters are not visible but :
/AcuCZK57hCNMAAAAAElFTkSuQmCC
For exemple where can i change parameters No1 and 2 .. .
Moreover it will be usefull to make visible the number of the parameter in config tab to match it wis the manual . . .
thanks . . .
Any reason why zipato don't support all parameter ?
some of the parameters are not necessary as with zipabox you can create some rule by using rule creator which we consider as the better way to do it. Anyway, very soon we will add an option to setup all the parameters of any device by using regular text string if there is no graphical support from our side...
Ok it's good thing but when ?
I think it's the minimum of service to have full support of device not only part of them.
