Fibaro Universal Sensor FGBS321 v2.1 - v2.3
Arno J. shared this problem 12 years ago
I try to use a Fibaro Universal Sensor FGBS321 v2.1 - v2.3 but I have some problem with available parameters. After inclusion, I have under control panel :
- Input 1
- Input 2
- Binary Sensor 1
- Binary Sensor 2
Normaly, following the operation manual, it should be :
- Input 1
- Input 2
- Analog sensor ( Temp )
- Output 1
- Output 2
Can you proceed to the descripor updae or tell me what is the link before each parameter.
With the Fibaro Universal Sensor it is not possible to control the outputs over Z-wave. You can only read the status of the inputs, which will also reflect in the outputs. I had the same problem and I think it is quite stupid of Fibaro.
I solved the problem with a relay module.
Ok with that but it don't tell me what is the mapping between input under the control center and ones idenified in the operationnal manual....
use
Binary Sensor 1 refers to the signal on Input 1 from FGBS321
Binary Sensor 2 refers to the signal on Input 2 from FGBS321
the TYPE of Input you can setup in Device Manager (Normal closed, Monostable ...)
Analog Sensor 1 or 2 (Temp) is shown if connected at powering up FGBS321
Output can not be controled by zwave (Note in the operational manual)
