Green Led is Blinking
Jean-Yves Bisiaux shared this problem 11 years ago
I just buy a Zipabox.
It had work till I tried to upgrade it from 0.9.999.1 to 0.9.999.2.
I unsuccessfully tried several time to upgrade it with an error message at the end of the procedure.
At the latest infructuous temptative, I powered off/on the Zipabox and now the green light is continously blinking.
- I checked the internet connection with the same cable on a laptop
- I can see the Zipabox IP address lease on my DHCP server.
- I turn the Zipabox power off/on several times
- I used the Button 2 + reset
Nothing change.
I really think that something is broken in the Zipabox software.
Is it a procedure to completly reflash the Zipabox OS?
I found the issue by myself.
My firewall blocked the network connection.
It will be great to have network connections details, flow/port/protocols.
Hello Ivan,
I have the same problem too. I have tried every combination. Even cleaning cache, updating in incognito window. And still on 0.9.999.1
