HMS100 "LIGHT THRESHOLD TRIGGER" is disabled and no way to enable
Maxim Shaposhnikov shared this problem 13 years ago
Not a Problem
What is the reason why it is disabled? I've been able to use it correctly with Vera3 but not with Zipato.
It looks like Auto Off time is not working as well...
Update - auto off time is working, probably it could be much better to provide something like Vera's "configure now" button to be able to push setting to device (because sometimes it could be done only manually - pushing some hardware button, etc)
OK, Marko, I see the idea. Probably you are right.
Anyway, is it possible to monitor / understand device configuration "pushing" process?
It was really convinient with Vera3 to see whether new settings already applied or not.
