Horstmann HRT4 doesn't reports current temperature.
And my danfoss thermostats aren't, working either.
Both are paired with the zipabox.
But I'm not able to set them.
I find it strange that they are both mentioned on. Website of zipato as fully compatible.
I have same problem too, climate manage temperatures well, HRT4 works too and i can change needed temperature from it until next climate changes. But when climate take hand it dont report the programmed temperature on the HRT4, maybe i ruled it wrong way
Same issue here, this is my bug in the climate widget... Should we put the HRT4 as an output as well or something?
H All, locking for a Solution on the Danfoss LC13 as well,... simple control option would be fine.
