How can I reset the alarm pincode
Anjos shared this problem 13 years ago
I try to enter the alarm dashboard, but my pincode does't respond.
There is no response at all. Tried to change the pincode in the setting. But also then, there is no response. Not from the dashboard and not from the Zipabox
Yes, I have still the same problem. Old Pin doesn't work and new pin doesn't work.
I did synchronize after the pin change
I tried the procedure you described. After number 4 i tried the pincode. After OK nothing happend. I tried it again with the standard pin 0000. Also then nothing happend.
