How to remove Z-Wave devices?
There seem to be no UI component to remove Z-Wave devices.
I suppose you would like to remove Z-wave device. Go to "ADD DEVICE" wizard, choose "Z-wave" and than select "RESET DEVICE", this is regular device removing procedure. After removal, you can just cancel the process of adding new device if you don't want to add any new device.
I've add a ZXT120 to Zipabox. Before remove this device, i reset ZXT120. Now i can't remove this device even if i follow yours instructions.
System says "Device reset successful", but it is always on Dashbord even after "synchronise" and "refresh".
I know i haven't do the thing in the good way.
I try to add an d remove ZXT once again, it's good, but the old ZXT is still here. I put it in "hidden" mode for the moment.
Hi guys,
My Zipato was tested before shipment to me. But, all the testdevices are still in the list of devices which ofcourse I do not have installed.
How can I return to factory settings?
Hi guys,
+1for factory settings
or delete device in dashboard
It is now possible to delete devices from within dashboard. Go to "device manager", right mouse click on the device which you would like to delete and select "delete".
It is still recommended to delete Z-wave devices which are operable by using "remove Z-wave device" within "general widget".
