HTTP device
Julien Wehrung shared this problem 13 years ago
It can't activate a http device's sensor.
However i can set decimal value for the meter.
Replies (7)
3
You are right. It seams we have a bug. We will look into it and keep you posted.
In the meantime you can use meter instead of sensor.
Thank you ! I actually use the meter, for the moment.
Any solution?
HTTP (virtual) sensor is now fixed. Active and inactive statuses are now visible when changing them with corresponding url's.
Thanks, it works fine
Hello Fred, any example for http device? Merci d'avance l'ami :)
I did a basic test, I do not have real examples and I'm looking for :)
