I can't registrer my Zipabox
JC shared this problem 13 years ago
I can't regsitrer my box on my.zipato.com. I always the same message : "the box is not online"
I open the HTTP and HTTPS ports on my router to the Zipabox's Ip, but nothing happen, I have the same problem.
I checked the serial numeber on thes box and on the label, the same...
When I connect a laptop on the network cable zipabox, I can go on Internet
Can you help me ?
Replies (5)
do you have a steady green light on your zipabox?
Yes I have a steady green light.
It seems you have a problem with the serial number. Please contact support@zipato.com (use the same email address which is registered with your box)
I had a problem with serial number. I contacted the support and i obtained a quickly response about us.
They resolved my problem and now I can use my zipabox....
thank you for your advices.
regards
I had the same issue. Contacted support using a ticket here, and they solved the issue the next working day.
