Ikea Smart Lighting
Pleeeeeeeeease make it to control with the zipabox <3<3<3
http://gizmodo.com/ikeas-working-on-a-super-cheap-and-versatile-smart-home-1707301488
Just got a tradfri bulb working with the zipabox with zigbee module. The trick is to get the bulb into inclusion mode : swith it on and off (toggle) 6 or 7 times, fast. So toggle without waiting between toggles. The bulb itself will respond with a very short flicker, that is the indication that the bulb is in inclusion mode. And indeed will be found by the zipabox. (Add new zigbee device, toggle 6 or 7 times fast, bulb flicklers, zipato responds with device found).
And now it's out to buy: IKEA TRÅDFRI: http://www.ikea.com/se/sv/catalog/products/10318263/
Will it work in Zipato controllers with Zigbee support? (Like the Zipatile)
Please let us know!
Please let us know!
As far as I know, TRÅDFRI uses Zigbee Lignt Link.
I don't think it is supported by the Zipabox Zigbee module, at least. Osram Lightify works without a bridge (Zigbee HA 1.2 protocol), but Phillips Hue does not (Zigbee Light Link protocol).
I think...
I think...
any update ? or do it support like Hue that you can link Ikea Bridge to Zipabox/Zipatile ?
Hello, any update they just started selling those very cheap: 9,99€ dimmable bulb.
I've seen an article where someone got it to work with Vera Plus, what I've heard from customers om mine the light is pleasing as well.
with the price tags of ikea, it will be interesting to have it working with the zipato ecosystem
Yeahthey got it partly to work with vera (not to change the colour) and not via the Ikea hub, just to end point right away.
Alsoseen people modifying the remote for the bulbs via Arduino, but that is ofcourse a more hardware hack
I just picked up a "Trådfri" 980lm Zigbee bulb from Ikea (with variable light temperature).
It sort of *WORKS* with Zipatile (Zigbee device inclusion, no hub): It's possible to control on/off, and both the temperature and intensity control show, but for now, I've only been able to control on/off from the panel. I guess the other properties can be controlled via rules.
