Improvments on Virtual Thermostat
Mats V shared this idea 10 years ago
I have problems when I adjust temperatures on thermostats. It´s very difficult to adjust temperature to the exact value I want. If i want for example 22.0 degrees it is very difficult to change the temperature bar to that value exactly. And why is it rounding up values? If I adjust it to 22,2 it rounds up the value to 22,5. I know some thermostats just can handle .0 and .5 but fo example qubino flush on/off thermostat can handle it in .1 steps.
Have any developer or other staff in Zipato used the Virtual thermostat object by them selves?
I think it´s better to have an up and an down button to step .1°C. And the same in phone apps.
The beta app has a simple + and - adjustments, this will make it easier for fine tuning. As for the .1 steps over .5 steps, do you really need that fine an adjustment? This will also depend on your Thermostat or valve controller as to whether it can support such fine tuning.
