inclusion of Duwi wireless switch
Tomcat shared this problem 12 years ago
I'm trying to include the Düwi wireless switch, without success. Durind the inclusion phase, it says that inclusion failed, but i can see a new entry in the device manager called "Reitz_Group_de:20482 PORTABLE REMOTE CONTROLER"
Except there, the device appears nowhere else, and i can't use it or associate it in rules or link it to another device.
Any idea ? thanks a lot
Replies (17)
Excuse me, i didn't understood your answer.
I saw that duwi 064336 and 05433 are compatible with zipabox but what about duwi 05460 ? This is a very interesting module because it can be mounted on wall and needs no wire (with 2 AAAA batteries)
i Have the same trouble. It will be fine to be able to use this device.
Marko Kosanovic wrote:
This device is not supported, only Duwi dimmer and switch in wall modules are supported for now but Duwi 05460 will be supported in the future.
will this be in the near future? i have the same problem..
Same Problem here, is important for me beacause actually is associate in single mode with Relay Switch Fibaro 2x1,5Kw and without this support my relay switch cannot include.
So what buttons are you using on your Duwi? Include button or up and down buttons? Use Include button, press it for 2 seconds to start inclusion. After that start pressing up button every 0.5s to keep device awake until discovery is over.
Hello Marko this does not work for me.I have tested it and it does not work
I have managed to include the device, it works !
it works!! thanks!!
Inlude doesnt work for me
i Had remove device, then reset
after i push the include button, until the red line start blinking green
then i push the the up button rapidly, until the device was found by the box
then after 10 sec the include fail
I had also try with continually pressing the up button to keep the device on, not better
Wath is wrong in my way to do?
Thank for your hel
It's Work for Me Thank !
Not yet form me, when i try to include i alway get a device found, and few sec later device not include.
What is the good sequence to add this device
thank
it's working for me with the new firmware 0.9.97 but with strange feature
some time i nedd to double clik the with to switch on or off
and in the rule we have access to 4 state ON-OFF-INCREASE-DECREASE
How can we use INCREASE and DECREASE, i Had tried simple rule without success (see attachment)
Hello Milan,
Yes, i've tried many times to remove and install it again. I even reset it two times, but it still doesn't work
The switch is the funksystem 05460 (wireless switch with cover plate included)
I simply would like to add it and then associate it with a Fibaro dimmer to have an additional switch for the lighting.
i've been trying the procedure described above, but without success. It keeps on saying that inclusion failed, (sometimes, even with failure message) it adds a new device (as said above the "Reitz_Group_de:20482 PORTABLE REMOTE CONTROLER". But i can do nothing with it, it appears nowhere except in the device manager
problem solved. Finally, i had the duwi switch correctly added. I had to try many times, but it finally worked.
Hello Tomcat, you can manually associate with other products (dimmers/switches) tripple click the up button and include a device that already has been included to the Zipabox.
I tried to include my Z.me wall controller today as well without any luck.
It sees it but cant include it.
Can anyone help?
Hello!
I m experiencing the same problem with the Zwave.me wireless switcher ref ZME_05460.
When I finally achieve to add this device, it appears as PORTABLE REMOTE CONTROLLER.
Any idea about this? Is that model working with the zipabox?
Cordially
