Integration of Axis IP Camera
Jérôme Tapie shared this question 12 years ago
I can't add my local Axis IP Cameras. Is it normal ?
Jérôme
Connect your camera to the same network which your Zipabox is connected to.
Click 'Add camera' and wait until Zipabox finishes scanning your network (it may take a while).
Once the Zipabox finish the IP discovery process, you will see a list of all IP devices in your network which do have a web server on port 80.
Check IP addres of your camera (by clicking check box on the right side of the selected IP address) and press 'Add' button.
Replies (13)
I am looking for a long time, and after two hours it still looking on the network ... The cameras are set to the same local network. What can I do?
Failing to perform the automatic addition, I try adding them manually. It still does not work.
I do not understand why it saves null / null instead of storing the path corresponds to the IP address of my camera. Where is the problem ?
Sorry for the inconvenience. We'll look into this and get back to you.
Have the same probleme here with EDIMAX 3110P, network scanning takes ages.
Solved? I have the same problem. I got 3 foscam cameras and can't find them.
Same problem with foscam
If I add it manually same problem
I successfully added 2 foscam cameras with the automatic discovery procedure.
Did notice though that it doesn't work if cameras are added manually.
Same here, add all my 3 cameras w/o any problems. Automaticly, one by one. All connected internally to port 80.
Why we must put our camera on the port 80 ? I put my camera on port 81, because if i want to access to my camera since my work i couldn't (port 80 is block on company proxy)
I think it might be a good idea to customize the port of our cameras and put the value that we want ...
You must use port 80 if you want to use automatic discovery, however you can add camera on any other port manually, when you are adding camera enter your camera IP and port (for example 192.168.1.5:81).
Good thanks a lot =)
Hey there,
For those who were able to integrate axis ip camera, What Mjpeg URL do you use, please ?
