ipx800
yves shared this problem 13 years ago
hello. I want my contoler ipx800 of electronic gce with http but it does not work. Here is my command: http://user:password @ 192.168.1.9:8090 / preset.htm? LED8 = 1
192.168.1.9 is your local network address. Is zipato on same network 192.168.1.* or on some other network that can access 192.168.1.9?
Is your command executed when you call it form browser (put link in address bar)?
hello.my ipx is on the same network that the zipabox. the problem is login and password. if login and password on ipx, the command is not executed, if no login and password control ok. thank you
Hello Yves,
do you have some pictures or examples for usinf the IPX800 with Zipabox?
Thank you.
Christian
