iTach IR Controllers
Will the Zipabox support the iTach IR Controllers or do you intend the make them compatable?
These enable any IR appliance (TV, DVD or audio) to be controlled via your Wi-Fi network.
http://www.vesternet.com/itach-wifi-to-ir
zipabox realy need to suport at least one IR controler.
I agree. But I think they are working on one from Remotec. The zxt-300 or some variant and of this. I think this is what the zipaboxtv unit we saw advertised a while ago was. Really wish they would hurry up with it though. This could be a huge selling point for Zipato. An all in one app to finally control everything.
That would be great Adrian. Would be nice if Zipato could confirm progres on ZXT-300
I was told that iTach has a new controller that supports HTTP, so virtual switch shut be poseble...
http://www.globalcache.com/files/marketing/datasheet_itach_flex.pdf
The Manual:
The Manual:
Actually Remotex ZXT 120 is supported for years now.
We have some iTach devices in the lab and considering supporting them.
Thanks,
Tom
Thanks,
Tom
The iTach flex works perfect!
To bad i cant use the commands in the rule creator....
And the commands cant be send from the app.
When are we going to be able to customize the icons on the app. I'll be damned if I can remember which number turns the tvs input from HDMI 1 to 2.
+one for IP2IR
+one for IP2IR
with FW . 0.9.999.4j codes are sent SUCESSFULLY acording to zipabox but NOT from IP2IR.
IP2IR works properly with same code from ILEARN.
latest FW also in IP2IR.
?/patrik
?/patrik
