join always fail for ZWave devices
dethurvi shared this problem 13 years ago
I just received my box and upgraded to last firmware version, all went fine
Then I tried to join two different Everspring ZWave devices : AN157 and ST814
Whatever my tests, the remove and reset procedures always succeed but the join always end by a "join not successful" error message.
I tried with the generic ZWave and all Everspring options, same result
Any idea to help me ?
Replies (5)
How far away is the device?
The plug is 2 meters far, the temperature captor at 10 cm
Message is "Device found. Joining device please wait. Join not successful."
I tried with devices touching the box
Unfortunately, it is possible that your box has the defective z-wave module inside. I think you should replace the box with your dealer. In case you have any problems, contact us on support@zipato.com
OK thanks for your support on this defect
I will return the box
