module 433
yves shared this problem 13 years ago
est-il normal que mon module Chacon LWST-605 double wall switch n' apparaisse pas sur le dashboard ,juste dans les règles ? Is it normal that my Chacon LWST-605 Double wall switch module number does not appear on the dashboard, just in the rules?
Yes, this is normal.
Chacon LWST-605 is a 433mhz transmitter device. You can only use it to control other devices. Therefore it's only useful in the rule creator.
