Motion activated rule, with memory
Christer S shared this question 11 years ago
Im looking for a way to include some sort of memory to my motion activated rules.
My rule now:
When motion is activated, light goes to 75%, after 20secs it goes down to 25% if no motion is present.
What I want:
When motion is activated, before the light dims to 75% as set in the rule, I want it to remember the level before it is activated, and then go back to this state after the time is up. If the value is manually set to 50% before motion is activated, I don´t want it to dim to 25% after, but 50%.
In PLC-world it is possible to write to a memory, then use the value in the memory later - is this possible in the Zipabox?
Is there any way to make such rule in the rule creator? :)
you should be able to middle store the values via creating variables. But be aware of that variables are reset up on restart of the device or other power loss.
Thanks! Worked great :)
Please show how you did.
