my zipabox blinking green
mcfly shared this problem 13 years ago
hello,
coming home tonight, seeing my zipabox blinking green and it was offline, the two security lights were off unit,
I unplugged the power, remove the security module provided the security module reconnected aware and working again normally and two security module LEDs are lit green and blue in the minute that followed
What can come of it?
thank you to you
Replies (5)
What happens if you disconnect to power to Zipabox with the backup module connected, does the upper LED on the backup module turn red?
Please contact us at support with your Zipabox serial number and user credentials.
last night, nothing happened on the module bakcup when I unplugged the power of zipabox by against the backup module is directly rekindled green when I reconnected the power of zipabox
against by now (as before, I did the test) if I unplug the power of zipabox the backup module lights red and the indicator on the zipabox flashes every 10 s
3
I just do another test, I unplugged the 220v, the module is turned on bakcup e trouge and does its job, I unplug the backup module zipabox it's put out, I knew rla zipabox reconnects, it remains extinguished, I reconnect 220v on zipabox the moduel backup turns on green, is this normal ?
merci à vous
merci à vous
Yes, that is normal, backup module is activated once it is detected.
But you shouldn't disconnect the backup module while it's powering Zipabox.
