Netatmo compatibility
Planned
ability to have temperature, CO2, etc. from Netatmo could be great
+1 That's definitely a must have :)
There is public Rest API available for Netatmo. It seems really straightforward but I guess Zipato devs already seen it:
http://dev.netatmo.com/doc/
Any news on this?
Already 20 votes on this one.
Any news on this?
Hello, any newas on this?
I'm using two Netatmo stations in two different locations. I'm quite satisfied with the Netatmo system, wich is complete and without disturbances. I have a very good control of the climate. It would be great if Zipabox could use the Netatmo sensors.
Before buying a second Zipabox, I will definitly wait that:
I want to be sure that my investement in this second system has a future.
Cantece
Cantece
I also want this...but you can use ifttt.com and google drive to send a http request. BUT it's limited.
Look here:
https://ifttt.com/netatmo
Look here:
IFTTT works perfect, would be nice to get value's in meters. They have API so that could do the trick, still i was not able to get temp or any other value retrieved to my meter for now.
Ok great.
You could rebuild this one to send values:
https://www.potsky.com/code/netatmo/
Ok great.
is this topic it is the netatmo weather station or the netatmo thermostat?
functions of the device are not the same
Weather station.
Don't think there's api for the thermostat yet.
Weather station.
i have create a topic about netatmo thermostat
https://community.zipato.com/responses/netatmo-thermostat-and-zipabox#comment-7995
could you edit the title of this topic please (netatmo weather station)
+1 ! Netatmo is the best thermostat, you can't do without Netatmo ! :)
Any news for the integration of the netatmo weather station to Zipabox?
A lot of us uses this device and we are waiting to connect it to our box.
it could be great to receive more feedback from the developer because a community is good but without feedbacks from zipato is a waste of time
Same for me, would be great to use the Netatmo weather station, including the rain meter in teh Zipato.
No news for netatmo compatibility ?
If netatmo not hapend, are there other CO2 sensor to link zipabox ?
2015 Q1 is the time for IP systems support.
Hi, can you please elaborate? I'm not sure what "IP systems" mean. Do you mean support for equipement with API reachable over TCP-IP/HTTP? Are you planning support for other equiptemt/APIs as well in 2015 Q1?
Thanks in advance :)
Anyway, more information will be available early in 2015.
any news or update in this ? can we expect a new firmware ?
-- > Anything..? news for netatmo compatibility ??
somebody has a good script to import the Temperature, Humidity and Co2 from all Netatmo devices?
Dont't need widget only a script that can run with a cron job.
Wondering if there might be any updates to the Netatmo, and more generally the IP system support?
Any news?
Any news?
Hello Zipato,
do you have an idea how many people use the Netatmo Weatherstation.
Please look here:
https://www.netatmo.com/weathermap
All these people can't use their sophisticated weather station will a lot of sensors within the Zipabox. They are very disappointed with Zipato.
What is so difficult with it? Please explain so that we can follow you. Other boxes have integrated the info from the weather station. Imperihome works with it without problem.
Hello Zipato,
Please look here:
"In Consideration" since 2 years. Please Zipato, could we have an explanation why Zipato is not compatible with our NetAtmo devices.
wait a little bit I'm 90% sure that Zipato will create a new pay option for this one :)
So we still do not have any support for the Netatmo devices, one of the major supplier for home sensors.
Any new ideas for the implementation of the weather station?
Where currently Zipato stands, they possibly will not make support in the near future. They have other higher priority items to do. In the above link DerHelle managed to integrate netatmo, and you only need a hardware in form of a webserver (possibly even arundino is enough) and of course some IT knowledge. If he did it, im sure others can do it as well.
Here is a workaround:
1. Download and install Eventghost on your computer.
2. Do this: http://www.eventghost.net/forum/viewtopic.php?f=10&t=7314
3. Add plugin Network event sender in Eventghost, and send the CO2 value at regular intervals, say every 10 mins to a HTTP meter you create in Zipabox, called CO2 levels.
4. Enjoy your CO2 graph in the new app.
Doeas anyone have a clue how to use the Netatmo API to integrate the values into Zipabox?
If you have something to store php file. You will be able to have all this information inside your Zipabox.
Have a nice day.
Have a nice day.
imperihome can use it, but of course then you dont get the values to zipato
Iam running domoticz.com parallel with zipabox
It has support for netatmo. I use a script to push values to virtual meter on zipabox
Reason I run parallel is due to I was a early adopter of zipabox duo in Sweden, and my duo’s 433 range is like 10 meters at max, I stopped using it and run domoticz on a PI with RFXtrx433E (range is great)
Hi!
I invested a bit of time on this. It works like a charm for me, is very useful to create rules in zipato based on this data (ex: cool enough outside to cool down inside, anticipate netatmo stations with battery HS, ...), and even charts work to show trends.
You need a virtual meter in zipato, a php script hosted somewhere, and a regular call to this php script to update your virtual meter. You can use a scheduler in a zipato rule and a http request in this rule to call the refresh (you can still call a cron task instead, for sure...).
You have other posts here and around in the net to deal with it.
PHP classes for netatmo API are here: https://github.com/Netatmo/Netatmo-API-PHP
FYI here is my (dirty) php code I adapted from other some sources, as netatmo api changed since the posts I found on the net, and customized for my set-up. To be adapted for yours!
(PS: it embeds many debug code, in comments, which may be useful to you to begin with)
Cheers
Hi!
Cheers
I wrote (yet another) script to fetch and push data (Lua script).
Did anyone overcome the 10minute delay?
I'm wondering if Zipato will finally fully integrate the netatmo products (API) , I've tried a lot of possible solutions without a good results, I'm still thinking that zipato must integrate this solution, what do you think ?
Also If I look on the Idea ranking is the next item to be build ... because the number of votes
Today I'm installed the new radiator valves from netatmo very good quality products but still no netatmo Integration in zipato ????? a shame https://www.netatmo.com/en-US/product/energy/valves
I'm currently using for netatmo > https://conradconnect.de/
But is true, is a shame.
After Conrad Connect integration, I guess we can connect NetAtmo products.
Anyone has tried this platform?
I tried it, but Conrad did not connect to the Zipabox. I do not know why. Perhaps because I have two Zipaboxes on the same account?
yes via Conrad I allways get this message
Something went wrong
Failed to refresh Zipato.
When In Netatmo plan on your roadmap guys ??,
We are preparing to publish few IP based integrations in Q1 2018. Netatmo is one of them.
that's a really good news ! thanks sebastian
Any News? Maybe already in february?
I'm using my netatmo temperature and co2 values already. You can set up an account with conradconnect.de and integrate your zipato device with netatmo and fill zipato virtual devices with the values from your netatmo devices.
But yes it would be nice and also I would prefer it to have a direct integration in zipato.
Beat
Beat
@Sebastian Popovic
We have Q3 now. When come netatmo?
@Sebastian Popovic
any news?
any news?
when it will work/ come? any news?
Still no news about Netatmo integration??
Feels like Zipato is falling behind its competitors......
Any News? Maybe with the new App?
