Nexa Device activity show up in Events?
Christian Hvattum shared this question 11 years ago
I have succesfully or not added 2 Nexa inputs. (I have not manage to get my Plugs or wallswithces to work)
1. LWST - 615
2. PET - 910
It took me a couple of attempts to figure out how things are working and it should be some more information about how to add when you start the inclusion process on 433 devices.
Now I'm trying to figure out if the system can receive any signals from these two and I'm looking at the events to see if there are any.
Do you log signals/activity from 433? Is there a way to figure out if they are working in Zipato? I have a Plug (PER-1500) that I have connected to both and it works fine.
In old dashboard and device manager you can see these (if joining was succesful), and also you can make bindind for some output device directly. Or for testing, you can create some virtual swicth, and make for example binding from PET910 button #1 to it. Then you can see if it functioning correctly.
Hurra, It's not easy to get things working but finaly. I now have a rule with my LWST-615 and PER-1500 working together. I tried to find a "binding" with 433mhz but it seems like it just Z-wave and I had to make 2 rules.
Now I'm going to try my WMR-3500 again.
Bindings can still be found from old device manager. And you can make bind between 433 and z-wave device. No need for rule, if you don't want extra functionality.
m79a5CzukOMna0IJ6Ys6
Old device manager worked fine, thanks
