No sync from rule creator
I made some changes (e-mail message) in my rule but now the synchronizing icon keeps on spinning.
When i close the window and go to the dashboard and go back to the rulecreator and open the same rule i see that the changes are saved.
I also tried to deactived all my rules and then sync. But problem is still there.
Fixed.
Fixed.
Oke great! It works now.
I have the same probleme since few days ... Still impossible to snchronize !
Try to disable all your rules then sync. If it works then turn them back on one by one to see which one is wrong.
I disabled all rules. I synchronized : OK
I enabled some rules. I synchronized : NOK I have this message ...
You have to look/find out which rule is the problem. Then post the rule that has the problem.
@MilSabords, when you press sync button on your Dashboard, do you get new sync time after message "Synchronization in progress"?
