Not possible to a have rules running !!
MilSabords shared this problem 12 years ago
I try to create different rules but impossible to have one ok (I don t forget to save)
Is it possible to see some Log to this rules. I have no error. So I don t anderstand what 's apen ?
Exemple of my last rule
Some help ?
Replies (6)
I'm a real newbie, but I'll make my best to try to help you ;)
What do you expect?
When there is motion in the bathroom, you want to switch on the VMC for 15 seconds, then switch it off?
Je suis débutant, mais je vais essayer de faire ce que je peux... ;)
Que veux tu faire?
Lorsqu'il y a détection de présence dans la SDB des enfants, tu souhaite allumer la VMC pendant 15 secondes puis l'éteindre?
Si c'est bien ça, alors je dirais:
If so, then try this:
WHEN "motion sensor sdb enfants" MOTION
(action) On/Off Switch VMC ON
WAIT 15 seconds
(action) On/Off Switch VMC OFF
En fait, ce srcipte doit eteindre la VMC si la fenetre s ouvre.
Quand ca marchera je mettrai un timer à 15minutes.
Mais je fais cela sur une "maquette", j ai le detecteur dans les mains et la prise à coté de moi.
Les deux fonctionnent bien . Il n y a que la règle, même simple, qui ne veut rien savoir.
Merci de votre aide.
If you need help, english!
I try to operate the Rules.
And Know I Just success to do that :
Scheduler on all 1minute / My Wallplug on and off ....
But When I Use switch (Be Next) state, nothing run. The box receive correctly the change of state of switch (control in log).
Is it possible that this type of switch didn t allow request send by the box ?
Ok we'll continue this thread in english so Kristian can help you ;)
He wants to turn off the CMV when the bathroom's window is opened, then turn it on again after 15 minutes.
I think you should try this:
WHEN "bathroom's windows" OPEN
WAIT 15 minutes
It should workTry with 15 seconds then tell us if it does itOtherwise, I think you can use your scenes if you prefer:WHEN "bathroom's windows" OPEN(action) Run scene VMC ARRETER (in english: STOP CMV)WAIT 15 minutes(action) Run scene VMC ALLUMER (in english: START CMV)Essaye ça, mais n'utilise pas le programmateur puisque tu dois utiliser l'événement d'ouverture de fenêtre pour lancer l'action "éteindre la VMC".La condition SI ne doit pas être utilisée dans ce cas.Elle serait nécessaire éventuellement si tu as d'autres paramètres à prendre en compte (je pense).
