Nothing is working
kevin shared this problem 11 years ago
I have juste purchase a zipabox.
I've started to configure it. for few minutes everything was fine unless the website that is soooooo slow.
I added blind control, switch relay and some other stuff.
But now it is impossible to control them. I can't close my blind!!. I can't open the ligth. I can't access the security widget (I doing the good pin code). I can't remove or add modules. Sometimes Zipabox appear offline even after lots of reboot and green light. Sync seems not working because shows alwas same hour.
I'm very disapointed and very unhappy of this product.
Could someone make it working?
Look here:
https://community.zipato.com/responses/problem-with-servers
but try powering down the zipabox wait a few min. then power up again.
Ok for the slowness of the website.
I have unpower the box for a few time. it seems to work but it is quite instable. Access to website too. It is very annoying for new user that have to set up their home automation...
Stick with it Kevin. I believe Zipato are the only company providing so many integration options.
I was intending to build a security system but I have come to realise that z-wave is totally vulnerable to a loss of power and cannot be used as the basis of a security system.
Now I have to hard wire my door sensors but I am very relieved that Zipato have a security module that supports that.
/Marcus
