One place for all temperatures
Marcus Khoo shared this idea 11 years ago
I would like to propose that the UI allow one place to see all thermometer readings
I have fibaro window/door sensors that have thermometers and also fibaro motion sensors that have thermometers. I also have a fibraro fire sensor with a built in thermometer, a fibaro flood sensor with a build in thermometer and a Aeon sensor that has a thermometer.
Currently there is no way I can see all the temperatures from one place. Some are in "Generic meter", some in "Temperature" and the thermometer in the window/door sensors are not available anywhere in the new Andriod UI
I would like to see all the temperature sensor output in the existing Temperature section.
:D
Replies (6)
You can use the filter option for this....yes, i know it's more clicks.
Hi HeroS,
Where are the filter options on Android?
/Marcus
Adroid app could have a favorite group also. Or more than one, as browser dashboard also should have. Then you could place particular meters to convenience group by association.
8cf8db9842d78f15044f72f6bf258193
On the top :)
Ah - but that is the PC interface and... yes, it is possible there. However, if you have an Android phone the following are true:
a) not all thermometers are shown in meters )
and
b) there are no filter options for the UI
(in my original post, I forgot to add the fact that the issue appears in the Android UI not the browser)
But thanks for your input HeroS
hehe oke :)
a) >> make sure that all meters are not hidden in the APP. Alle meters should show up in the meter section.
b) >> Yup, you are right.
If you have question/problems with the APP go here:
https://plus.google.com/u/0/communities/107959331935751006364
