Param issue for keyfob aeon lab
Ludovic Couturier shared this problem 13 years ago
Not a Problem
Hello, I a m trying to install keyfob from Aeon Labs. The inclusion really works fine at the first attempt and a module is added in the list. My problem is coming from when I try to parameter it. In order to use it in scene mode I have to setup parameter 250 with value 1. But Zipabox tells me that the param 250 "already exists". Can you tell me how can I reallocate or delete it?Thank you
Thx for it, it seems logical.
Just one information more. As when I quit "setup mode" on the keyfob, nothing appears in the zipabox I would just like to know if I have to add a parameter for each button? Do I have to create one for each actions.
Milan Gulis wrote:
Hello
Aeon Labs Keyfob is fully supported with Zipabox and thus parameter 250 is already configured and available under configuration tab of this device. This parameter is called "Mode selection". By default, this parameter is set to "1".
Keyfob is in default "Setup mode" so it can be included to Zipabox. So after you add it to Zipabox and before you start using it exit "Setup mode" by pressing "Mode" button on keyfob once.
Here is our community post regarding Aeon Labs keyfob:
http://community.zipato.com/responses/aeon-labs-key-fob_2
