Philio Smart Color Button (PSR04)
Daniel Stein shared this problem 9 years ago
I bought the above mentioned Button. Unfortunately the only thing I can bring to live is the level input in degrees. Pressing the button brings no result whatsoever.
Has anyone a solution to solve this?
Thanks in advance.
I would suggest you to open a ticket on https://support.zipato.com/ include your serial and UUID of the device, they will be able to help.
By default Group 2 is not associated to the Zipabox.
  1. Edit the settings of your PSR04
  2. Open the advanced tab
  3. select "Manage associations"
  4. select "Group 2" on the left of the screen
  5. select the Zipato Controller on the right of the screen
  6. Click "Send"
Now your PSR04 will show up as a device with a slider.
I have created a rule with 5 levels:
0 = all off
1 to 32 = scene 1
33 to 65 = scene 2
66 to 98 = scene 3
99 = scene 4
/F1CXICFXhWQjAAAAAElFTkSuQmCC
If you want to control scenes with two PSR04 buttons, you can add a virtual dimmer and let de PSR04 buttons control the virtual dimmer.
/vVAAAAABJRU5ErkJggg==
i'm sorry....switched left and right..
it must be:
  4. select "Group 2" on the RIGHT of the screen
  5. select the Zipato Controller on the LEFT of the screen
  6. Click "Send"
