Philips Hue no endpoints
Bastian shared this problem 10 years ago
Hallo Leute,
ich habe Probleme mit dem Einbinden meines Hue Systems. Ich hatte es bereits vor einigen Woche hinbekommen. Nach dem Reset bekomme ich immer "keine Endpunkte" angezeigt. In der App funktioniert alles. Ich habe bereits die Hue Bridge ausgetauscht, wiederhergestellt usw... immer keine Endpunkte.
Hat jemand auch so ein Problem?
Vielen Dank schonmal
Grüß Basti
Replies (14)
Hello Ivan,
i tried it already 20 times... I don't know where the problem is.
I have the same issue - writing with support - no help at all IVAN - just basic try new cables - try with DHCP - and linking to the same video https://community.zipato.com/knowledge-base/article/philips-hue-adding it is not working. On the other hand, a Ras Pie with Domoticz on it, works perfectly on the same network, ther must be something not working for Zipato here.
Same here. If i use HTTP request i get it to work but that is alot of work.
i´m on firmware 0.9.999.6d now but still not working.
Please let me know if i can help with tests.
Hello guys,
we had troubles with debugging since we were unable to reproduce this issue, inclusion always resulted with all the endpoints on Philips HUE for us. We tested a fix with a few of our Users and this issue was resolved. A fix should be released with the new beta firmware, the one after 0.9.999.7c.
Fantastic - when is the ETA on the new beta ? :)
I
Hello Martin,
new beta is scheduled to be released within the next few days.
I'm on the version D now, still Phillips Hue is not working "Failed Configuration" - and via the Mobile app while adding the Hue it added my Hikvision Security cameras. "What!" - so toke all units off the network only my pc modem zipabox and router - still error. Using https://www.domoticz.com/ open source solution on a RP2 it just workes "every time"? Was it supposed to be fixed in version D.
I still on the C beta version and they sent a fix to my box and it is working.
Got all Bulbs but the names are not correct.
Get the names right and it will be perfect.
Still to try them in the rules...
Hello Martin,
have you deleted the old Philips HUE, the one without endpoints? Please delete it, Synchronize your Zipabox and try the inclusion again.
Hi Hrvoje,
Yes!!!!!!!!!!!!!!!!!!!!!!!! :0)
I did go under IP and delete the Phillips Hue - and made a SYNC.
Than tryid again and for the first time ever - i now have Phillips Hue Bulbs available under Actuator.
Thats so fantastic! Thanks Zipato and keep up the fantastic job!
I´ve got the same issue. I can include the Philips Hue Bridge 2 (with HomeKit Support), but it has no endpoints/devices to control.
It worked perfectly with domoticz and raZberrys zway but now i switched to zipabox with fw 0.9.999.8q and i can only include the bridge without any lights (one Iris and two Strips+) :/
Maybe it is a problem with user-rights for the api access?
I have the same problem. Tried deleting and syncing but nothing works! Can someone please help?
Try to upgrade to the latest beta 8x4. Then do the same procedure - remove, synch, include, synch.
and make sure that all lamps are on during the inclusion!
Do you have Philips Hue? Is it working for you fine? I know they had problems before, but I dont know right now if these lights are working fine or not.
working fine? not at all... : ) But i remember that it was important to turn all lights on for a successful inclusion
Worked great :) Thank you very much! And thanks for the fast reply!
Hello, im having the same problem - no end points. All lights were on. Tried that for 100x...
Thanks for advice
Daniel
