Please support products from: qubino
HeroS - www.domotica-blog.nl shared this question 12 years ago
http://qubino.com/
Replies (13)
One month and no news in supporting this new item?
Marche tres bien en on off sonde température ok mais la consommation est fausse dommage
Tu as trouvé où l'adaptateur pour brancher la sonde de temperature?
Salut je l ais trouvé dans un magasin de modelisme ils ont ses fiche sur des cerveaux
Bonne nouvelle MyDomotics vend la sonde avec l'adaptateur (pas donné par contre)
http://my-domotique.com/store/index.php?id_product=785&controller=product&id_lang=2
@Milan Gulis
any info on power consummation data support?
I have a qubino dimmer and the zipabox dashboard shows the current consumption ok. I don't see cumulative consumption, but it might be that my led lights haven't consumed enough yet.
I also haven't been able to have the qubino dimmer module react on commands in scenes.
I have a Qubino ZMNHJA2 (fil pilote). Is it to support please?
Thank you, Jérémy.
qubino temperature sensor does not appear in cliumat control as input.
The Qubino ZMNHJA2 (pilot wire) does not seems supported.
No "Supported by Zipato" on it's page and device Device is said as: "Unknown manufacturer"
The found Endpoints are:
Group2 (any idea what it means)
Group3
Group4
Group5
POWER_SWITCH_MULTILEVEL (the dimmer that does the activation)
SENSOR_BINARY (I guess I1)
SENSOR_BINARY (I2)
SENSON_BINARY (I3)
Id the temperature sensor is plugged is not found anywhere (it is not hidden as it's said for thermostat module).
Nevertheless it looks like the temperature can be found in the
POWER_SWITCH_MULTILEVEL endpoint events as VALUE1
SMp2T2hxHTUPHzn2RXiu
But how can I use this values in thermostat vue?
Is the consumption measure now supported? From what I read in many forums the Z-Wave Qubino Flush 1 Relay is recognized by the Zipabox, but not the consumption function. Is it still true?
I have now Qubino flush double relay connected about 24h. And consumption readings are working correctly (almost, at least. Cumulative seems be quite low, but possible anyhow).
