Problem between Zipabox and Oregon Scientific THGR122NX
Chrys shared this problem 10 years ago
I'm a Zipabox's french user.
I use Oregon Scientific THGR122NX probes with Climat Widget.
I have 3 Climat Widget with 3 probes for 3 rooms.
Occasionally, Zipabox has stopped reading data from 1 probes during 1 or 2 days then reading again without reason.
Therefore Climat Widget doesn't work.
Can you help me to solve my problem ?
Chrys
Replies (15)
Hello Chrys,
You can try changing communication channel, changing the batteries, bringing probe closer to the Zipabox and avoiding possible interference.
Thanks for your reply.
The batteries are new.
The probes pilot different Climat Widget in different room, it's impossible to bring its closer to the Zipabox.
I will change communication channel but i'm not convinced....
The problem is aleatory.
Chrys
did you delete the device and add it again?
Helle
Yes, the first time I have this problem, I deleted the probe and add it again, but always the same thing...
do you have the possibility to change the device (THGR122NX) maybe its broken?
Helle
3 probes run correctly because their screen display good information.
And because Zipabox read date again without reason.
I think it's a problem of communication but which problem ?
Am I the only to have this problem ?
Chrys
Do you have a normale Weather Station from OS?
Than you can test the Sensor.....
Helle
Sorry, I don't understand what you said.
What is a Weather Station form OS ?
Yes, I have a station like this.
I will test sensors with it.
I have also this problem. I guess its a wrong contact in the oregon. Mine is working now but I must not move it!!!
I tested the sensor with a station but I could not connect sensor with station.
But sensor work again with Zipabox.
It's an another sensor (THN132N) which does not work now and last week, a THGR122NX sensor does not work with the Zipabox during 2 days and work again at once
It's incomprehensible.....
Chrys
Hi, do You have a remote (for the freebox mini 4k ) or another radio remote ?
Hi Jacques,
I have radio remote for my A/V amplifier and for my TV (but I don't receive TV with a Internet box, just with a simple TNT decoder).
I'm very disappointed in Oregon sensor with Zipabox. It's not successful !!
And no Zipato's programmer take seriously the problem
Chrys
Same problem for me site THGR122NX since an update in octobre 2014, before all my 9 were working Well with Zipabox
