Problem compatibility fibaro fgk-101with zipabox 2
GENTILE shared this problem 6 years ago
Hi every body,
I have a zipabox 2 in v1.3.72 and i try to include several fibaro fgk-101 door captors.
the inclution is correct but after the installation the captor is see like binary sensor and there no state change (opene and close)
I have try to change the type of the module but result is the same.
some on have had already this problem with a bad installation of this modul and find a solution ?
i add that I have used this type of modul before with my zipabox 1 without problem.
thanks for yours answers.
I would liek to inform you that FGK-101 is supported in Ziapto platform, so please upgrade your firmware to the latest beta version and try to include it again. If there is any further issue, please submit a ticket and our support team will check it and help you to fix it.
Hi Dino,
thank for you answer,
I have upgrade my box with the 1.3.98 version, unfortunatly it's worst. now it's impossible to remove a node, make a inclusion or exclusion...
I will to reinstall the official version and I will to open a ticket.
Mat
