problem with 433 MHz Module
Thibaut shared this problem 13 years ago
hi,
I connect the module 433 Mhz on slot 2 and my zipabox is offline.
I have last updated, i have synchronize, and after several reset it's the same.
I need a little help
thanks
HI, where do you have purchased it?
And what can you tell me about CoCo compatibility?
Milan Gulis wrote:
Hello
It would be best, that you contact us on support@zipato.com with your Zipabox username and password, as we will need to connect to it to be able to debug this.
Also, try do following:
- unplug Zipabox from power supply
- connect 433 module
- restore power supply and wait until Zipabox comes Online and give me feedback on what kind of LED indication was present on Zipabox.
It should be like this. When the power supply is restored, Zipabox should have a yellow LED indication, which means it is booting up ( approximately 1 min max). After it there should be blinking green ( establishing connection to the cloud ), and final, steady green LED ( connection established, Zipabox Online ).
Question, do you have any other expansion module connected to your Zipabox except 433?
in response to your email, 10 minutes after my LED remains yellow.
Remaining at your disposal
PS : when I send an email to me support@zipato.fr it returns indicating that I am not registered
You can buy it here : http://www.domadoo.fr/produit,3636,1,ZIPATO--Module-d-extension-RF-433MHz-pour-Zipabox.htm
