Problem with Aeon multisensor configuration.
Jki shared this problem 11 years ago
In Aeon multisensor config tab, i need to set two buttons "on" on the same line for report content . Now it is impossible, if i click another, previous go "off". And fourth button going "out" from sidebar.
However, it is impossible to make any changes, because saving gives error message.
G7K88j5IKDb0I84ivHG8
Other device config saving seems give a same error. There is new tab, "advaced", that can be reason.
This issue seems be partially repaired now. Configuration saving is functional. But still from new UI, it do not save what is included to which report. And it still not allow to choose more, than one item for line(report). Even as default, there is two items selected in one report. But if you try to change anything, it leaves only one selection for line available.
HuefEF9bZCF06tVsx1mi
