Problem with "Run program" function climate widget and HRT4-ZW thermostat
Fabi shared this problem 13 years ago
I'm running firmware 0.9.974 and trying to control the thermostat Hortsmann HRT4-ZW with ASR-ZW receiver.
Everything seems to work fine to control the thermostat, both ways (zipabox to thermostat and thermostat to zipabox), except when I Use the "Run program" function of the climate widget.
If I use "Until next period" or "Permanent hold" the thermostat behaves correctly, and temperature is set accordingly. When I use the "Run program" nothing happens on the thermostat even when I wait for a while.
Is this identified as a bug, or did I misconfigured something ?
Thank you !
Replies (6)
Is it the same problem as other ones also reported ?
I'd need to get the thermostat installed asap, any answer would be appreciated.
Just the "Run program" doesn't work well, otherwise it looks fine, really a shame I cannot program the thermostat and install it definitively.
Thank you.
If "Until next period" and "Permanent hold" is working than there is no reason that "Run program" won't work. If you configured your "Week program" and when you set "Run program" do you see correct program name and temperature in widget?
Indeed, in the widget it displays correctly the "Run program" changes, but on the thermostat itself it doesn't have any impact. On the contrary "Until next period" and "Permanent hold" do control the thermostat correctly.
I have a similar problem. When using "Run program" the climate control goes to 22 degress regardless of the program I have set. "Until next period" works fine.
It says you problem is solved, how did you solve it?
Please let us know how.
