Problem with the synchronization: impossible to synchronize rules
Julien shared this problem 13 years ago
Dear zipato team,
I have a problem with the synchronization of the Zipabox. Indeed, it's impossible to synchronize rules with my Zipabox.
More precisely, when I click on "Synchronize rules" button, the window "Synchronize rules. Please wait" opens. However the window don't close. The rules are saved but are not synchronized.
To solve the problem, I tried to reboot my Zipabox 2 times, but the problem is always there!
Do you have any explainations? Did I make any mistake?
Kind regards.
Replies (7)
The problem is more important in fact.
All rules don't run anymore... :(
It's seems i've got same problem . . . after make some change in my rules sync ok.
But after several change, got the same problem . .. sync don't work . . stay in synchronizing pop and nothing happen . .
what firmware are you running?
At the moment, rules synchronize and run.
Firmware : 0.9.971
Thanks.
I deleted a rule and the problem disappeared.
I experience the same problem when something is incorrectly created. Deactivate rule by rule and see... Then try to figure out the issue... I had problems when i used a variable incorrectly. Hope it helps!
i have same problem
