Problems for include
Anthony MANIC shared this problem 13 years ago
I try to include sensors, receivers and transmitters (FGK101, Alarm sound BENEXT, remote Chacon). But when including the Zipabox does not detect it is 3 days.
Could you verify that there are no worries.
Thank
Page is locked to "Starting" or/and zipabox is offline
For the inclusion of a sensor Fibaro FGK10 the page is often stuck on "Start". Sometimes the countdown starts but zipabox but does not detect the sensor or Fibaro BENEXT Alarm sound (I do not even try the 433 module)
Hi Anthony,
I had the same problem with the FGK101 but got it working.
What i did:
- Pull the power plug from the Zipabox
- Wait 30 secs
- Put power plug back in to the Zipabox
- Login to dashboard
- Make sure the the door sensor is close to the zipabox
- Pull the battery out of the door sensor
- Wait a few secs
- Put battery back
- Add devices >> select >> generic zwave >> add
- Then push down the doorsensor (so the back TMP is pushed) and push the front TMP button many times (fast)
- Also make sure that the sensor is in the closed position
- Keep on holding it down
- Then the doorsensor should blink slowly
- Zipabox should find the sensor and add it
If it doesn't then reset the zipabox again and see if the devices is there (total devices). For me the countdown did not start but the devices was there after reboot.
Hope this helps. If not >> contact support@zipato.com
Issue with the 433 receiver devices has been resolved in 0.9.985, please upgrade.
