Qubino temperatur as input for climat control
I do not find the possibility tu use the Qubino temperature as climat control input.
The Qubino device is included completly with switches, meters and temperature.
It is intersting, that the temperture is also not shown in ImperiHome.
i have the same issue. if you look into the rule maker, you will se that you can not use the temperature in the rules. the temperature is indeed displayed on the dashboard, but not accessible threw the rule creator. That is a bug. I notified Zipato team through a ticket since almost a year without any answer.
I use Qubino ZMNHCD1 Flush Shutter Module. I also can't use de temperature into the reules. :(
