random and abnormalities
Noghaard shared this problem 13 years ago
hello
I have a big problem with my box since I bought that persists despite the latest firmware update.
The rules I create works of random manner: either very well or partially.
Worse, having tired of this situation I wanted to disable all the rules but they remain active. I have removed all still the same they always work.
The only solution is to unplug the box. GRRRR ....
Obviously I always synchronizes the box after each change in the Administrator interface. As harmful it took me a long time to be certain that the problem was not due to an error on my part.
But I really need your help for my zipabox working properly and not partial and random way.
Thank you kindly help me.
For me it is catastrophic for the M.A.J. 0.9.981 in the Fibaro modules (modules 3-4) move randomly online and offline but never the same modules?? And M.A.J. 09982 and the result is Zipabox which passes online and offline, a battering the LED is white, it flashes green, and sometimes three or four flashes and fixed, but the worst is that modules do not meet the Zipabox tells me no defects. Only modules that are self put off work (module configuration). More on community.zipato I posted a message and no response! So more automation, the rules no longer run. I do not know what to do, a little help would be appreciated.
Same for me. Most switches don't work anymore, or randomly. This is since firmware 0.9.982.
Please, correct it soon !
When you say "both of you", does that include me? Could you check my box as nothing seems to work?
Thanks,
Philippe
Thanks, it now works.
Philippe
