releys of the zipatile
What are they the releys who are in the back of the zipatile and you can connect?
For switching. Out of the box one is configures as relay for a gas bioler (dry voltage) and the second as a relay for a cooling system (dry voltage). Obviously you can connect any device up to 1A, so it can even be a light if it is less than 200W.
if I want to connect an air conditioner I can connect.
And how would connect?
You would need to send model number or even better, installation guide. If the air conditioner support IR commands, perhaps it would be better to look into Zipato IR extender and in the manual search for your brand. If it is there you should be able to fully control it via IR commands.
