Removed devices removed BUT not removed from dashboard
Jérôme Chomé shared this problem 13 years ago
I have removed several devices (to add them later) but even when correctly removed, they stay in the dashboard and there is no way to delete them.
For example I paired the thermostat HRT4, it was correctly added as a thermostat, then removed it (it didn't disapear but was succesfuly removed) then I added it again and the I had 2 thermostat. One with parameters not changing and the other working correctly. And it is impossible to remove the old one.
Exact same thing with the door sensor Fibaro FGK. They stoped responding so I removed them from the box (but they didn't disapear from dashboard) then added them again and they appeared as new door sensor but the old one are still there :-(
Anyw way I can remove them?
Thank you for help.
Jerome
same problem for me with a dimmer switch aeo
