Rules doesn't work after update to 0.98
gpo shared this problem 13 years ago
As indicated since I have update to 0.98 my rules are not working anymore (for the moment checked with rules using scheduler)
what should I do ...it's urgent as my swimming pool is piloted by the zipa --> loose of $$$
Replies (6)
I just sent the request to zipato support and my request was denied:
"Your ticket has not been accepted into the system. This is the support desk for the active Zipato users only.
If you are a registered Zipato user, please, send the email from the email address which you have registered with my.zipato.com."
the request is sent with the same email used to post this message
could you help ?
similar problem here, time based rules seems to stop working.
Milan Gulis wrote:
Hello
We have located a bug responsible for the problem with rules. It is not related to latest firmware update. Problem with rules is caused when rules are synchronized while they don't have complete data. Chance for something like this to happen are very small but as you experience, it is possible.
Unfortunately to fix this you will have to recreate those rules that are not working.
Could you please explain what do you mean by rules having not complete data? My working rules in the past, suddenly stopped working... I am not sure if I follow you
All my rules using "Time xx between xx and xx" no longer run since the update
Can you fix this bug quickly ?
same
solved with the V0.9.982 and the upgrade server (18/07/2013) :
>"Here is an update regarding this issue with rules containing "Time between".
This rule puzzle now works but there is a bug where winter and summer time
counting isn't taken in account. So your time will be off for summer time
saving. But this is already resolved and fix will be actual after an server
upgrade which should be over by end of day.
Milan
Reason why there were so many down in last few days was because of Open Source
framework Atmosphere integration. This wasn't easy integration and it was very
time consuming. Till now we were using Comet web application model in which a
long-held HTTP request allows a web server to push data to a browser, which
caused some user not to see fresh data on dashboard until they refresh browser
with Ctrl+F5. Also there is possibility that there will be some server
maintenance because of it, as there is always some fine tuning that must be
done.RegardsMilan
