Run rule in RULE CREATOR and show where it stops?
Jacob Wiqvist shared this idea 11 years ago
https://www.youtube.com/watch?v=pcVRNL18ie0
It would be very helpful to the user if they can just click the rule you created to run it, and something that marks where the rule reads and where it stops. Then you can quickly see if the rule is working or if you have done nothing wrong.
I work as robotic techniques, and it happens that there are errors in the programs that control the robot too. But then you can go into the program and run line by line. Or forced to run from a specific row. This would be convenient if you could do in ZIPATO CONTROL CENTER.
Then one could also see where the rule stops.
I rather have a system that doesn't created errors. So it would not be possible to make a rule that doesn't run :)
That is a god ide but if you create a large rule it could be hard to find the problem more than that the rule creator complains that the rule can't be created and if 90 % of the rule is correct it could be hard to find the error? Or am I just imagine that this could help.
But you could have a system that is possible to run parts of the rule but can't save it until all is ok.
Any way this could be to advanced to create.
