Save the state of the dashboard and widget filter values
Julien Wehrung shared this idea 13 years ago
Planned
Can the filters on the list box and the order of columns can be saved between each sessions ?
State of the dashboard, size and position of widgets, are saved in your browser cookies.
Currently we are not saving filter values, but we will in near future.
Replies (5)
I re-arranged and resized the panels and are saved.
Filter list is not saved, tried to resize this panel also to check in the evening what happened in the morning. Seems like the number of events is limited. Eventhough the eventpanel on the Ipad is capable of checking this
Yes, position is solved.
But, for example, i need to re-select which device is show in the current value widget.
Or i need to re-filter the events widget to show something.
Widgets are empty by default, and i think it can be more friendly to set them with default values.
(saved, not solved...)
Automaticly adjustment of column width in event log? Or saved as manually set
